Yessss! If @tjub gets on a roll here, this thread will really be kraken!
Maggots
A Reaver recreation inspired by @Uther.the.unhinged’s daughter!
Start with a chubby log with rounded ends
Roll grooves
Optional step. Use one flat side and one grooved side to knock down the amplitude of the grooves. This step is unnecessary if using small plates, debatably necessary with medium plates, and likely necessary using large plates. Do this very lightly, only one or two passes.
Large, medium, and small maggots using the same plate pairs respectively. I post processed nasty faces on these with a dental pick. The larger one might benefit from some teeny leg texture as well which could be added after cure. Gently squeezing your maggots at each end will result in a relatively fatter looking maggot. Any fingerprints resulting there could be remedied with a wet sculpting tool and/or as part of making the nasty maw.
Worship Nurgle, if you’re into that sort of thing.
Ammonites
A Reaver recreation from this video at about 4 minutes
Create a conical tube similar to step 1 of roots tutorial
Using pair of large plates, try to maintain the cone while creating grooves. It can be hard to do this without blurring the texture as the plates want to slide down along the cone. Try your best to maintain the plates relative position and only translate them along the grooves. I find that a couple of deliberate strokes here is best as opposed to many repeated passes. This one took several tries. You’ll figure it out!
Coil it up using a tool ideally pressing only in the grooves so as not to disturb your work. Getting the coil started is the tricky part so make sure the tool is wet.
I have a MIGHTY NEED for these. I cannot share any other details at this time
Here’s a sample of these embellished with barnacles and snail ladies.
Great tutorial!
Updated the ammonite post with final results that will be used in my familiars unit.
Snakes
Align two same size plates with corrugation parallel. Pictured below with both plates facing up for display purposes only.
Translate plates along the diagonal as shown vertically in the picture. Try to keep the plates from moving horizontally to keep the texture crisp. This should give you some diamonds on along the tube. If they end up too pronounced for your scaly preferences you could GENTLY come back over with one flat plate and one corrugated side to knock the ridges down.
Place snakes on plane. Not very many of these came out crisp as I was still learning on the fly, but maybe this still gives some kind of idea.
Spiral tubing
Align two same size plates with the corrugation 90 degrees from each other. Pictured below with both plates facing up for display purposes only. This is similar to crosshatch tubing except you will translate the plates along the diagonal.
You are in a roll @Reaver
I’ll see myself out
Very similar to previous makes from @Reaver but another great use is making tails (for skaven or what have you)
Start out by taking a small pea size ball of greenstuff.
Roll it out into a small sausage, giving it a slight taper.
Use the back of two plates to taper it more until you got it at the desired length.
Use the large plate from the small tentacle makler set and roll the tapered greenstuff between the plates, grooves aligned the same way.
Then, very gently, smooth out the beads made by the tentacle roller and add a sharp tip to the thinnes bit of the taper.
Lastly you can add some twitst and bends to them to make them look like tails and add that dynamic movement to them.
EDIT: Oh and a little trick @Admiral has tought me… these thin tips can get very fragile, coating them in superglue after the GS has cured makes them a lot more durable!
Excellent tutorial! Flawless results. Super glue is king to give green stuff tips toughness.
Could it be tails (from left to right) number 1, 3 and 9?
Could be! I honestly cant remember!
